Is anybody running a front mount intercooler with their b6t in their festiva? If you are did you actually find a kit that will work with our cars or you just made your own. thanks
Tags: None
I should be getting an SRT4 intercooler from Dustin soon... but right now I'm using a Saab Blackstone intercooler mounted under the hood (which sucks).* Retired Festiva-er*
1990 Festiva - The Once Fastest Red 1990 Festiva LX on this site! - now in more dedicated hands!
B6T'ing since May 2002...
Disclaimer: I'm a dick, deal with it.
re:
You can use exhaust pipe for your intercooler tubing if your in a bind. It even comes in diameters all the way up to 5"!! It is a bit heavier, but it will work. Anyone give any thought to hooking a pair of smaller intercoolers up in series? I have seen it done on DSM's with decent results.Fast, fun and good gas mileage. 91' Festiva(RIP) and 96' Aspire(RIP). The website is no more.
the Audi TT uses dual intercoolers, one in each fenderwell. Some people on vwvortex have datalogged lower intake temps and less timing pull with the dual sidemounted setup because it leaves the radiator with plenty of airflow so the engine stays cooler, allowing the ecu to advance timing farther and create more power. So if you're in a pinch and have two smaller intercoolers laying around and some pipe, it'll work, just try to keep the piping routed as directly as possible with minimal bends and such.
