check this out
  • check this out
    any ideas or comments?
    Ford Festiva 1992 Model, 1.3L 5 Door, Red, Mods- Roo-Bar with two spotlights, also stickers, on the bonnet, front window, and rear window
    Yes
    Yikes
    Clinton
      wasnt there a tornado air thinggy like that?
      may be worth it if your driving a gas guzzler like an RV but i dont think it would be worth it on a festy
      90 L FI..second B3
      90 L Parts car
      Jay
        snake oil
        www.dantheoilman.com
        Go ahead and ask me why
          Those things aren't worth putting on any vehicle. All it does is restrict the air flow. Some engineer with a massive brain designed the festiva air intake to get the right air/fuel mix, no swirling vortex of terror is going to make that any better.
          OX SMASH!!
            You'll get better results with a good old A/FM tweak.
            1998 Kia Pride CD5
              A/FM?
              90 L FI..second B3
              90 L Parts car
              Jay
                air fuel mixture?
                  A/FM trick = putting a resistor into the VAF that fools the computer into thinking the intake air temp is lower than it really is. Makes you run richer and gives a tiny bit more power. Ofcourse, it also makes the engine run cooler which can foul the plugs and then you lose power.
                  I need to start selling something like the turbonator. Maybe a little electric powered wheel that drops down below the car and helps push, or retractable wheelie bars for that suped up Accent. I could make a fortune on the stupidity of others.
                  On second thought, I like my current profession.
                  OX SMASH!!
                    no No NO NO NO do not do that you are asking for problems. the resister is a very bad idea ask jim. Every hear of ring wash? to much fuel when the engine is hot is a very bad thing. trust me. and if you don't talk to jim!
