will it fit in a g25mr? or any other trans? has anyone tried?
miata clutch?
miata clutch?
Mike, AKA the sasquatch
1990 LX, bp+T/g25mr, 9psi dynoed at 194HP, turbonetics t3/to4e 57trim, haltech E6X standalone, 550cc injectors, turbosmart wastegate, synapse BOV, walbro 255 fuel pump, aeromotive FPR, AEM wideband, 3 inch exhaust, huge FMIC, 9LB flywheel, 6 puck clutch and way more parts that im forgetting i installed lol...Tags: None
What is the spline count on the miata clutch? You would probably have to use the miata flywheel and pressure plate. But the big question would be why? There are plenty of performance clutches to use with the G-series tranny that you would not need to look at using a miata clutch. Do you have something in mind or some part you would like to use?The Festiva Store
i saw a clutch on CL, thought it was a good deal. the only problem is that it is for a miata. i dont know the spline count, i think ill phone him and ask him for some specs.
from what im reading i think the egt and miata clutch are the same, so it will work? just to make shure, is the 323 gt and egt clutch the same? also a little off topic but no big deal, im kind of confused about the trans's in cars, is the 323 gt cable and a egt hydraulic clutch pedal?
Poverty produces creativity
