Hello! I'm finding some Festivas locally for sale, mostly 4-speeds. The 4-speeds seem to rev really high on the highway. How hard/expensive is it for the DIY person to get a junkyard tranny and upgrade to the 5 speed? Eventually I'd like to drop in a B6T. Any advice is appreciated! -Ward
Difficulty Rating of 5-Speed Upgrade?
The five speed tranny is the exact same as the four speed except it has overdrive. It is really easy to change out.The Festiva Store
The only thing you would need is the tranny, because they are exactly the same except one has one more gear in the case than the other.The Festiva Store
actually the 4spd has overdrive too.Originally posted by nonamekidThe five speed tranny is the exact same as the four speed except it has overdrive. It is really easy to change out.
the 5spd has TWO overdrive gears...which is why it makes your car so slow, even when swapped
Wil
02' Sc00by WRX Sedan (current project)
00' Celica GT Automatic 38mpg gas-sipper (sold)
05' Scion xB box-on-wheels (sold)
93' MX-3 Hybrid on LSD (sold
96' Slowtegé 42mpg Beast-mobile (engine exploded)
93' B6-ZE 'tiva GL aka"Blue Bomber"(now owned by darpien)
I would think for maximum stock transmission performance, one should stick with the 4 speed, since it would be a few pounds lighter.
If one wants more mechanical advantage in acceleration, go with the five speed from the Aspire, which has the lower final drive ratio.
Am I right?
What would be the difference in weight between the 4 and 5 speed trannies? I would guess maybe five to ten pounds. Not much anyway.
Going to the 5 speed will improve your mileage on long trips though, and is well worth it for that alone (plus maybe some noise reduction).
