I have an 88 carbed Festiva. According to Haynes, the spark timing is controlled by the ECM as well as the carb jetting.
Can anyone explain this in more detail? Is the Haynes manual right?
My Suzuki Samurais have a feedback carb, but the ignition is not controlled by the ECM.
Haynes states that the spark timing is computer manipulated until the engine reaches operating temperature, and then the dizzy functions without computer assist. Or maybe I interpreted Haynes wrong.
An altitude compensator also influences spark timing, but it operates independent from the ECM.
My goal was to maximize the static (initial) advance using the 'power timing' technic. I don't want to battle the ECM though.
Power timing is where you keep advancing the timing until pre-detonation becomes a problem, and then back it off just enough to avoid the ping. It gives you free horsepower and increased efficiency.
