hey guys. brand new to the board...
you guys seem like some knowledgeable hacks... so here goes.
i have a 1988 festiva... has 201,000 miles on it. seems to run well, save for a bit of valve tick, and a little oil burining. that is gonna be a beater for my G/F. but it will eventually be needing attention.
i also have the chance to pick up another dirt cheap festiva... also an '88. it has some tranny issues...pops out of gear. but i was thinking that at the price, it'd make an excellent project. 5 speed tranny is a no brainer... as if there's a unit with higher ratios, thats usually what i like. the engine also has about 200,000 on there. but if it is better than the one that is in my g/f festiva, i'd swap it out, so she could have a decent run around machine. that would leave me open for all kinds of fun. the car wouldn't be my primary get around, so it would be ok to be a bit junky for a bit. i w as thinking using a masda B6T (i have read about this a lot on the web). is the B6T the same as the B6 (just with turbo)? would either engine be a good replacement? i know running a turbo engine in a 1700lb car would be pretty hot. looking for feedback, and tips from those who have done it before. if it is a difficult process, it doesn't have to be modded out... i can live with stock... ha ha ha. just most of my mechanical abilities are basic, although i am sure i can do an engine swap, with a manual, some advice from those who have donbe it before, and a couple friends. any feedback you guys could give would be great!
