:confused5:The heat is impressive, I wondered .. there was any kind of mod that can be done to radeador so that the temperature drop in the level of normal temperature?
i change the water pump and valve electro-fan, and his temperature is normal, but I would like to be a little more low temperature, to offset the extra heat is generated, when you turn on your air conditioning..
some ideas?
some ideas?
