So after doing about $1100 dollors worth of work to my festy i found out that my transmission (5 speed) has a small crack in the housing that somebody JB welded and is now leaking again.  I went ahead and JB welded it again but now im not gonna feel safe with the car.  I know that the housing tend to be kinda weak on the festiva, what a better transmission i can put in there, a 323?  The engine runs so good and doesn't even have 100k on it yet, but would it be easier if i just went with like a complete swap
Festiva Tranny Weak
Festiva Tranny Weak
(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
New: Tires, Axels, Front Wheel Bearings, Fuel Pump, Valve Cover Gasket, Carb Rebuild, Timing Set, Belts, Shoes, Distributor, CapRotor, Wires, Plugs, Coil, Grant 11" Steering Wheel, 3700 Watt Stereo System-6 1/2 Infinity speakers, Infinity tweeters, Almani 12" subsTags: None
yeah, i dont know much about the internal workings of a transmission, but i am mechanically incline and i know things dont just happen. I know that the crack is an indication of something else going on inside, so anyways what do u suggest? stock tranny replace?Originally posted by lastplace View Postleaking fluid isnt the only problem you're gunna have. its cracked cuz the gears sets are pushing away from each other and the crack will just continue to grow until the tranny is completely useless(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
another thing that i just happen to have on the festy i'm parting out...
problem is i'm probably a couple months from pulling the engine and shipping it would be helllll
JoeJoey Richard Jr.
1991 Ford Festiva L; died but donated all her organs
1988 Ford Festiva LX; EFI swapped in...actually everything swapped in
Quality is Job 1. Together, We Can Save Lives. Ford.
I actually do think that is the case, cause i had the clutch replaced about a year ago and i know thats how the guy took the axels out. The guy was an idiot and i shouldn't have let him touch the car, but at the time it wasn't my car so i didn't care, either way there is a crack that had been sealed with JB weld. The guy i took it too now said it was leaking from where the JB weld was originally put on, but the guy who replaced the clutch hadn't filled the tranny all the way up with fluid so that it wouldn't leak, and when my new guy did the work on my car he filled it to the proper level and thats what exposed the leak. He suggested just putting a few more layers of JB on, so hopefully it will hold up haOriginally posted by wrestler3025 View PostOr the crack could be from someone trying to remove stubborn cv axles by prying on the case with a crowbar or other tool a little too vigorously.(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
If you still have the stock engine, I would just put another festiva tranny in it. You shouldn't need to upgrade it.The Festiva Store
I'm with nonamekid on this one. If it's the stock engine and you don't plan on doing an engine swap anytime soon, I would just put another festiva tranny in. I would try grinding off the old JB weld(be careful not to damage the transmission) degrease the area really well and give the JB weld another shot. Prep is important though. Having a good surface to bond to doesn't hurt. Good luck.Originally posted by nonamekid View PostIf you still have the stock engine, I would just put another festiva tranny in it. You shouldn't need to upgrade it.90 Festiva with Brand new B3, 5spd
92 B6 Festiva, 5spd
Or just try to get an Aspire 5 speed transmission. Since you want to keep the B3 this trans. will give you better acceleration and it wil have newer components than an older Festiva 5 speed. It should be a straight swap,someone correct me if I am wrong.There is replacement for displacement! Less weight and BOOST!!!
Aspire trans case is slightly different (and widely considered to be weaker), and requires some customizing to the front trans mount to work in a Festy. The lower final drive ratio will also throw off your speedo reading by several MPH.Jim DeAngelis
jim, if i'm not mistaken, the aspire trans uses the same 90 tooth speedo ring that's in the festiva... so in that case, no speedo worries.
also, if it's weaker, then why have the ribs on the case?Trees aren't kind to me...
I've done this and didn't realize it, then i drove the tranny 3 hours from home to change it for a member here, once i got the old tranny out, i noticed the crack on the tranny i was about to put in, i wasn't too happy that dayOriginally posted by wrestler3025 View PostOr the crack could be from someone trying to remove stubborn cv axles by prying on the case with a crowbar or other tool a little too vigorously.
I'm not saying the cases are weaker, I'm just relaying opinions I've read here. Ribs are often cast in to offset thinning of the housing.Originally posted by FestYboy View Postjim, if i'm not mistaken, the aspire trans uses the same 90 tooth speedo ring that's in the festiva... so in that case, no speedo worries.
Yes, it uses the same speedo gear, but that is the problem. The Aspire has a taller tire to offset the lower final drive. To correct the speedo error, the driven gear would have to have additional teeth to slow the output. Otherwise, the speedo reads about 10% higher than original.Jim DeAngelis
umm the ring gear spins at wheel speed, so if the speedo gear is the same, you'll still read the same road speed, but your RPMs for whatever gear you're in will be different. right? knowing that, the differance in tire hight between festy and aspire STOCK sizes is .5" (not that much, and i still contest that the festy speedo is off with the 12" tires)
it'll be darn closeTrees aren't kind to me...
My tires are 9% taller than stock in my aspire. So that is what a festiva feels like? What a dog. No wonder engine swaps are so much more popular than on the other forum.1993 GL 5 speed
