take your old worn out air filter and turn it in to a new high flow air filter.
take yor old air filter and tear off all the paper and throw it away. now you are left with a metal screen and rubber seal/ border, like so:
next find a pice of foam that is high flow enough for the job. i used a old kfx 400 one.
cut it to look like this:
now start to zap strap or sew the foam to the screen. ( if you cut the zap straps at a angle it is easier to poke through the foam.)
once you are all done with the zap straps throw some tape around the edges like this:
and for the final step, drill out the rivets and pull off that thing on the side of the box, like this:
now you have a air filter that would make K&N drool ....... lol i hope this helps some people ( im shure it won't lol)
