I just bought an 88 L with 220K and the motor time is about up. I am wondering the complexities of swapping in the fuel injected motor from a newer Festiva. I am on a tight budget and need to get this thing on the road again. Please help! Thanks.
Fuel Injection Swap into an '88
two routes you can take, it can either be easy or very complex.
1. swap in the block, use the 88's intake and exhaust manifold. swap in the camshaft and fuel pump for the original motor. swap the pulleys on the alternator so you still have the choke heater stator plug. (easy way)
2. replace the gas tank, wiring harness, fuel lines, ecu, and then swap in the fuel injected engine. drill holes to mount the radiator and air box.(complex way)Jesus is on my dashboard, But the Devil is under my hood
1988 ford festiva...in limbo, apartments suck
1995 Ford Aspire...in limbo, wow i need a garage
2002 vw jetta wagon 2.0L, neuspeed p-flow 1994 Mercury cougar xr-7 v8, lowered, 18's
