mounts
  • mounts
    Does anyone have any good pics of BP mounts found a few but would like to know if there is anymore. Would be mounting a hydrolic trans from a 95 EGT.
    The trans mounts have me puzzled the most. How do you know if both axles are straight or as close as possible??????
    Anything for a Festiva:thumbup::thumbright:
    I have seen all of these but would like to see more.
    Anyone willing to build 4 mounts for me for a cost of course?????
      Here's the tranny (G-series) mounts in my B6T car
      Where the rear mount bolts to the crossmember has been modified for a round mount to bolt flat to the cross-member, although my mounts are thick nylon it doesn't bolt in the centre, but being solid mounts it doesn't matter anyway, one day i'll switch it to rubber mounts
        Keep the transmission to engine mounting surface in the same location left to right as the festiva trans. If you do this then you'll have no problem fitting the axle. And push it back as far as you can. I had to grind a bit off 1 spot on the trans to get it closer to the steering rack. Make stiff mounts since there isn't much room for things to move around.
        3 mounts is enough, some have a 3rd mount on the top of the trans. Look at the link above for the mount thread. There are many different ways.
          THanx but the front mount has the clutch cylinder by it looks like i have to put the Festy sway bay back on for that mount to fit.
