Fuel injector Flow charts
  • Fuel injector Flow charts
    All these are 13.9 ohms & high impedance/saturated injectors by Nippon Denso
    Injector #_____Flow rate___color____found in
    195500-2110 - 120cc - purple - festiva
    195500-1670 - 130cc - green- mazda 323
    195500-2040 - 186cc - gray - Mazda MX3, (83-87) 626
    195500-1970 - 212cc - blue - 1.6L Miata
    195500-1280 - 230cc - blue - (90-94) N/A Mercury Capri, before 93 Ford Probe/Mazda 626 2.2L SOHC F2
    195500-2180 - 254cc - brown - (90-94)Mazda Protege , (91-96)Ford Escort Gt, 1.8l Mazda Miata All BP motors
    195500-1300 - 300cc - dark/navy blue top - (91-94) Mercury Capri XR2 B6T, Before 90 turbo Mazda 626/Ford probe
    195500-2150 - 326cc - Beige - Mazda MX6/Probe turbo F2T (90-92)
    195500-1350 - 460cc - red - Rx7 N/A (88 ) have square plug (89-91) have oval
    195500-2020 - 550cc - purple - Rx7 turbo (88 ) have square plug (89-91) have oval
    are you sure about all these colors i have a miata1.6 fuel rail und the injectors are gray and bp injectors look beige not brown but i also havent seen the probe turbo injectors to compare colors. are bp injectors light brown or dark? i am just asking cause we are using these gray injectors in our turbo b3 project if they are 186cc or the bp 254cc injectors. and do you know what size the stock b3 has.
    YOU WILL HEINZ 57!!!!
      I had posted this info I found a little while ago:
      Ford Festiva......1.3L sohc 8v B3...195500-2110 ........120 cc/min.....13.9 ohms ....purple
      Mazda 323.........1.6L sohc 8v B6...195500-1670 ........130 cc/min.....12.7 ohms ....green
      Protege/Escort....1.8L dohc 16v BP..195500-2180 ........230 cc/min.....13.9 ohms ....beige
      Mercury Capri XR2.1.6L dohc 16v B6T.195500-1300 ........300 cc/min.....13.9 ohms ....dark blue
      ~Nate
      Current cars:
      FOTY 2008 winner!
        thanks updated
          I'm injector shopping now as well. Will injectors off early 90s hondas/toyotas bolt in the same, as they are probably densos? What cars to avoid have low impedance? I have some out of a yota but do not know the size. If they are in the 200cc range they would work as well.
          Oh i found this.
          1993 GL 5 speed
            so i want high impedance(sp) injectors?
              90s 323 B6 injectors are not Green, they are Brown.
                Are Aspire injectors the same as Festiva?
                  No listing of/for the Brown 94-97 Ford Aspire B3 injectors? is that because this chart is for High Imp. ? and the system on the Aspire B3 is a Low Imp. ?
