B3 turbo project
  • B3 turbo project
    I have an OBDII aspire and i want to run a turbo setup because i can't really do an engine swap. I'd like to know if a B6 oil pan will bolt up to a B3? A guy on the 323 forums has one pre bunged for the oil drain back.
    Facebook Me!
    ketchup and i are building manifolds for the b3 pm if your interested. and check out the kit we built for my festy
      I saw, I may just take you up on that
      Anyone know about the B6 oil pan bolting up? the Early B6 from a BF 323 that is.
      Facebook Me!
        if it's a steel pan, it'll bolt right up
          A whole b6 will work in your aspire. You just need to retro a crank sensor. My 1997 engine is still at my moms, i can provide you the pulley/bracket/connector so you can put it together on a stand. There is a write up on aspire.com on how to make a 94/95 work in an obd2. Pretend a b6 is a 1994 engine and it will go.
          If a b3+T can keep up with a BP, a b6+T will pull one.
          1993 GL 5 speed
