First off it is a 1.8 with escort trans.
Need help in wiring the reverse lights, I found the wires on the harness but unsure how to wire it. The backup lamp switch has 4 wires to it 2 green and 2 blue and my harness has only two black yellow stripe and red yellow stripe.
I believe the switch it on the front side of the trans.
What about the switch by the shifter on the rear of the trans does it need to be hooked up and where does it go????
Thanx for any help
Thanx for any help
