do we even HAVE an IAT? Queenie, it's a waste of money, that resistor just tricks your ECM into thinking it's -40* ouside and in turn raises the timing and fuel output (wasting fuel).
I wanted to experiment with the error codes so I tried disconnected the iat sensor & there was a code 10 error which is the iat sensor. Once the error starts, you should connect the iat sensor back on and disconnect the battery and press the horn or the brake pedal to remove any ecu current, if you don't it will not reset. I tried it myself. Anyway, I tried connecting a 20k resistor instead the iat sensor and no codes at all, even with a 50k resistor in series with the 20k = 70k no error codes at all. So the iat mod works very well. Also, it increase the responsiveness of the engine, also revs smoother and even gets better mpg's.
What it will do in our cars, at least mine is to make the ignition timing more advanced across the rev range so, it will run more efficient and stronger at the upper rev range. It will not increase fuel as someone is saying, To increase the fuel you have to put a resistor on the ects (engine coolant temperature sensor), then it will run pig rich and will not start. I will never touch that sensor but the iat is a good mod. I never bought a chip but I found a 50k ohms resistor, disconnected the wire from the vaf and connected the resistor, one end going to the ecu and one end to the ground.
