My carbs came from the Ford KB laser, sold in Australia. It was fitted on the Mazda E5 engine. Here is one currently listed on eBay:
Here are some pics once this listing is finished:
Since the E5 ports are slightly wider on than on the B6, an aluminum adapter plate had to be made in order to route the air and fluid. You will need a piece about 1" X 3.5" X 13"
I had to modify the location of the center bolt hole of laser manifold to bolt to the B6 cylinder head.
Here is what I started with:
I bought a couple of plastic 6mm wing nuts, although the steel Geo wing nut holdown could be used instead:
In my next installment, I will discuss the intake gasket modification I made and why.
Cheers.
Cheers.
