Hey all,
A couple of months ago i bought a Mazda 121 Funtop then promptly damaged my left hand during an oil change
Since then the suspected head gasket problem manifested itself(which is good really as it is helping me with contesting a speeding ticket, there is no way i can do 80km's an hour at 3500rpm running on two cylinders :shock: )
I am picking up a '92 festiva (Aussie carb'd) which is out of registration and pulling the motor out of it and dumping it into the Mazda so it runs and i have time to do my thing with the original block (matching engine numbers on chassis on block is always a plus with the authorities)
:angel4:
So i now have movement on my hand and will be rebuilding the block :roll:I am going to Bore it out to 1.6 to give it a little more kick. Maybe somewhere around 85hp+ (i want kick and zip not kamikaze red-line). Wherever ever i have the option i would like to take torque over ponies :wink:
Here's my thoughts
-Light port and polish to the head
- high compression pistons (sourced from a newer model 8v engine) as it only be running on 98, do i need to bother with this ? (like will the smaller head have a smaller combustion chamber?)
-Twin Carb intake manifold (heaps of old 85-88 Mazda 1.5l have these) OR switching to EFi (aftermarket would be cheaper here) OR fabbing up a custom intake manifold to run quad-carbs from a 1100cc bike (if the carbs flow enough fuel for a 1100cc bike at 9000rpm then they should be able to flow a 1600cc at 6500rpm right?
is there anything else i should do?Cams? Valves? :?
I want to keep it basic as i am keeping an eye out for 85-88 B6DE engine, which eventually i will rebuild the block once more with the forged internals and Twin-cam head
:idea:
So things like extractors and muffler will prob be counter productive to the budget, it's also going to be driven by my younger sister so I'm staying away from forced induction. (i do however like to know she driving a responsive vehicle so she can accelerate out of the way)
Best of all if the engine number is the same i can say i didn't know the internals weren't stock (which will last me as an alibi until i bolt on the b6DE head
All input welcome
:angel4:
Here's my thoughts
:idea:
)All input welcome
