Originally posted by joebreck117
Kia pride cold air intake on b3 engine.
:festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
Originally posted by lancerevo View PostLook at the pictures correctly and see where the pipe is located. It's before the filter, and the other hole is not blocked. I left it there to have 2 air flow holes and the difference is incredible. Before I had a cone filter & it was not the best idea because, it was still sucking air from the engine compartment. I can tell you that now is making much more power + the engine temperature is less.
oh, and where is Malta????
-Aspire brake swap COMPLETE!
oh okay i see it now. i thought you scrapped the old intake and made your own tube...basically i thought the gray pipe was going to the engine.
but i see it now. very cool.Joey Richard Jr.
1991 Ford Festiva L; died but donated all her organs
1988 Ford Festiva LX; EFI swapped in...actually everything swapped in
Quality is Job 1. Together, We Can Save Lives. Ford.
Originally posted by ejp2fast View Postoh, and where is Malta????
It's here just off the southern tip of Italy:
Ian
Ian
