I'd like to install my MSD Ignition and coil to the car, but with doing so, I would like to advance my timing. What is everyone on here doing? I've always advanced my timing on my V8 trucks about 6 degrees over stock.
Timing Advance
One adjustable cam gear from a DOHC (bp) protege/miata motor will work with a b3/b6/b8 sohc motor.Last edited by festivaWES; 08-20-2009, 09:35 PM.---------------------------------------------------
I'm sorry, I'm not following you here. Your saying I have to swap out my cam gear?Last edited by mturner2003; 08-20-2009, 09:42 PM.
For an adjustable one...or you can give the dizzy a schoshe turn...
How else would you advance the timing?---------------------------------------------------
Sounds like we're talking about two different issues here: adjusting ignition timing and valve timing. The original question was about ignition timing. For sure you can do it, just use premium gas to avoid detonation. I'd recommend going up in 2-degree increments; when you hit detonation with premium gas, back off 2 degrees.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
THANK YOU... good grief, lol! Had me all bass akwards. I'm going to bed now.Originally posted by TominMO View PostSounds like we're talking about two different issues here: adjusting ignition timing and valve timing. The original question was about ignition timing. For sure you can do it, just use premium gas to avoid detonation. I'd recommend going up in 2-degree increments; when you hit detonation with premium gas, back off 2 degrees.Last edited by mturner2003; 08-20-2009, 09:58 PM.
This is the 21st century we use METRICS!!! 14mmOriginally posted by daniel_cogar View Postnot the whole cam just the gear (the timing belt wraps around it) passenger side of engine under plastic cover .. there is one bolt holding it on I believe it takes a 9/16 but I may be wrong-daniel---------------------------------------------------
