I know, I know. There are posts everywhere about this, use the search. I did. I just want to clarify exactly what I need for a swap. SO, I've got a carbed '89 4 speed P.O.S.tiva (there's a new one, for ya) that needs a swap. I'd like to put a b6 in it. Is this correct- I need the engine assembly (duh) from an 88-89 323, the CPU, and the engine wiring harness? If the motor has EFI, I have to replace (for some reason) the gas tank and fuel lines, too? If I want to keep the carburetor, I can switch out the manifolds, but also need to switch the cam? So, for the easiest route, get a carbureted 323 motor, the computer, and bolt it in, right?
Free cars are never really free.javascript:emoticon(':x')
Mad
Thanks!!
Mad
Thanks!!
