Today I went out and did a couple of mods to the stock Aspire airbox. Like all airboxes on modern cars, for noise reasons it is more restrictive than is useful for the engine to efficiently take in air; i.e., the hole coming into the airbox is much smaller than the hole going into the VAF, and the black tube going over the valve cover.
1. Undid the wing nut holding the black tube to the upper rad support; undid the hose clamp (10mm) connecting the black tube to the VAF; disconnected two electrical connectors on the VAF; snapped off the four clips holding it to the lower airbox piece; set it aside.
2. Pulled out the air filter--it's new; removed one 10mm nut and one 10mm bolt securing the lower airbox piece; pulled it out.
3. On the front of the lower piece is an intake horn, secured by three phillips screws; removed it, saw a much bigger hole in the lower piece than on the intake horn. This mod alone will probably give a noticably easier-revving motor. I then drilled fifty 1/4" holes in the front and fender side of the lower piece. This will give plenty of air flow, probably more than the stock filter can use: an extra 2.45 square inches, not counting the larger stock hole revealed by removing the intake horn.
4. Replaced everything except the wing nut pieces on the rad support; in fact I removed the bracket that was there. It seems unnecessary, and a minor hassle.
5. Went for a drive. When I stomp on it, there is definitely more intake roar, so it's getting more air. It does seem to rev more freely above 4000 RPM, but that's subjective; no real numbers here. This mod will of course not affect fuel mileage if you are driving for economy; it only makes a difference above about 4K RPM. I do this type of mod to every car I own.
