Here is the diagram to make a low price, almost no cost at all performance mod. I have tried it myself and it worked. What I did was put a 22k ohms resistor between the iat/vat sensor and the ecu. Here's the diagram. The difference is more torque and power and feels power full in the high rpm range, small increase but noticeable. Right now I am using  22k ohms resistor but I am going to try the 15k resistor soon. Using the 15k resistor is the max resistor you can use because the manual says so. I will try and see what it does.
The vat wire is green and black.
