Originally posted by blkfordsedan
Has any one installed a 4 in 1 header on a b3?
[QUOTE=mattdickmeyer;333709best gap .028-.030. Just some info.[/QUOTE]
I have a set of ngk bpr5es and tried your gaping setting and it backfired a lot while decelerating, so I went back to stock setting .044. What is the cause of that back fire?:festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
from what i know its 1 7/8ths from the cat back... and i think the downpipe is the same...
Mike, AKA the sasquatch
it's 1.5" ID just so you know.Trees aren't kind to me...
ok... i thought it was 1 7/8ths.... shows you what i know... lol
hehe, no prob. most replacement pieces will be that 1 7/8" dia. but the factory unit is smaller (DOH). strange thing is, the new civics with the 1.5 use the same size pipe as the festy (1.5").Trees aren't kind to me...
mine had 1.5 inch piping for EACH tube comming off the head when i built my header
 lol...
that's BIG for a B series.Trees aren't kind to me...
made alot more top end power tho... and it was still the stock mid pipe in the car so if i went and got a 2 inch mandral bent pipe and took out the cat i bet it would have made even more power...
would say 60-70 cfm int. 110-140 portedOriginally posted by sc72 View PostMatt, what do you have for flow numbers on the B3 head--stock trim, then flowed.Last edited by mattdickmeyer; 05-24-2010, 07:43 PM.PROPOGATE! AND FACILITATE!
Poverty produces creativity
