Ok, so when I bought my car, I was told that it had a new coil.  So, I never thought about changing it.  Then in another thread, I read that putting in a high performance coil will help when driving up a hill.  Well, it didn't seem to help driving up a hill, but it has given it much more pep than I thought it would.  Before, I could get up to about 35 MPH at about 3500 RPM in 3rd gear.  After installing the msd coil, I can get up to about 50 MPH at about 3500 RPM in 3rd gear!  I never would have guessed a b3 with the 4spd would have ran this strong just by changing the coil.  It makes me want to get the b6 or b8 swap done now!  More power=More FUN!  I am very happy with the results I have gotten from a $20 MSD coil from Silv3rBull3t!
MSD Coil swap
You have a model number or anything for the coil? I might look into getting one"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
All I know about it is what was listed.
MSD Blaster 2 coil
I didn't notice any numbers on it when installing. I ended up having to use the factory coil bracket because the one that came with it held it weird. I hope this helps. You can check with him and see where he got it and if he has a part # or anything for it.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Last edited by TominMO; 10-24-2009, 07:08 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
^^ I keep toying around with that idea, Tom, but mine is running so good at the moment I hate to mess with it. Not sure if I'm going to mess with advancing the timing, but I'm thinking at my next tune up, a high voltage coil, heavier duty wires, and indexed plugs are definitely on the menu.
1989 L - 247K miles Slick
Go for it! Advance the timing a little too; you'll notice the diff. Unless you just want to keep using the lower-grade gas; it's prolly gonna get a lot more expensive soon; i.e. when the Israelites smite the Persians.Originally posted by batstiva View Post^^ I keep toying around with that idea, Tom, but mine is running so good at the moment I hate to mess with it. Not sure if I'm going to mess with advancing the timing, but I'm thinking at my next tune up, a high voltage coil, heavier duty wires, and indexed plugs are definitely on the menu.Last edited by TominMO; 10-24-2009, 07:35 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
+1 on the timing advanceFestiva: Because even my dog can build a Honda.
+2 advance!!!Trees aren't kind to me...
Originally posted by hofficergrover View Postthe msd blaster 2 part number is 8202 i work at a parts store jsut sold one
Thanks For the Information Grover,I'm getting Mine Tomorrow
						1993 Ford Festiva GL "My Cream Puff & new project"
1998 Isuzu Rodeo
1994 Suzuki Intruder 1400cc "Da Cruiser"
1999 Chevy Silverado Z71 "My Work Horse"
1994 Isuzu Trooper "Camo Off Road Beast"
1989 Festiva L Stock Engine "Rallytiva71"
Daily Driver,Rally Racing Look,Little Additions Daily. *******Sold*******
FOTM October 09/ October Page FF.Com 2010 Calendar.
http://www.cardomain.com/ride/3810528
I have no doubt that the new coil helped performance, but this defies the laws of Physics!Originally posted by doylerl View PostBefore, I could get up to about 35 MPH at about 3500 RPM in 3rd gear. After installing the msd coil, I can get up to about 50 MPH at about 3500 RPM in 3rd gear!
Speed and RPM are directly related. It is a function of tire diameter and gear ratio. If 35MPH = 3500RPM then 50MPH (in the same gear) would = 5000RPM and 70MPH would = 7000RPM. See the connection? Twice the MPH, twice the RPM. If you change gears then you are changing the gear ratio, but as long as you stay in the same gear the correlation remains the same.
If you swapped the coil and your Tach actually reads a different RPM than the old coil at any given speed then you have a wiring issue.Brian
I thought the same thing. That is why I was so impressed by it. I am being truly honest. I don't know what the wiring issue would be, because I ran the tach wire myself directly to the coil from the tach. The only thing I messed with was the coil, and I hooked all of the wires back up just how they were on the old one. Any other thoughts on why it may seem like that? I just figured better spark giving it more torque / hp, but I don't know. As far as the timing, I have never messed with anything like that, and I would be afraid of messing something up. I have been told by several people that a minor adjustment there, and you gain more power. I believe that is probably my last option to get it to be "not so doggy" going up a hill. I lost 20 mph AFTER the msd coil install going up a hill! I am just wanting to maintain speed for now until I can get another job and can afford a swap. Thanks everyone.Originally posted by blkfordsedan View PostI have no doubt that the new coil helped performance, but this defies the laws of Physics!
If you swapped the coil and your Tach actually reads a different RPM than the old coil at any given speed then you have a wiring issue.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
