this is my header & cai that i built
b3 header & cai pictures
nice, puts my rusty header to shame
 lol... looks like the same shape tho... where is the collector?
Mike, AKA the sasquatch
Would you consider building headers for other peoples' B3s? I could use one or two.Originally posted by mattdickmeyer View Postthis is my header & cai that i built90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Wish I had one...................... With a lever long enough and a place to stand, you could move the world..........
..................Build thread.................http://www.fordfestiva.com/forums/sh...ad.php?t=29547
that must sound mean... when i switched to my header it gave it a deeper tone... any sound clips of it?
What pipe diameter re you using for the 1.3? Also, can you make it with a flange to mate up to the stock cat at the stock location, so it's a simple bolt-up? How about a bung for the O2 sensor? And how much would you charge?Originally posted by mattdickmeyer View Posthere is the collector. yes i can manufactor this header.Last edited by TominMO; 11-05-2009, 10:10 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I'm also interested in the answers to these questions.Originally posted by TominMO View PostWhat pipe diameter re you using for the 1.3? Also, can you make it with a flange to mate up to the stock cat at the stock location, so it's a simple bolt-up? How about a bung for the O2 sensor? And how much would you charge?-93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
-85' Nissan Sentra 5 spd.
I would also like a couple. Tired of waiting for the "other" guys to do something.Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
l designed this header to work w/mildly stock 1.3 engines. w/that in mind, my figures came up w/1.375 in primaries & 28 in primary length. The primaries are arranged in the collector in proper firing order to promote all around performance & drivabiltiy, scavaging. VE(volumetric efficiency) w/this header is around 4000 RPM. l also biuld a stepped header for highly modified egines that has 1.375-1.5 in primaries. lf you want pictures of one being built l can do so. All of my headers come w/two 02 bungs & are high temp coated. Price would fall around $250. As for the turbo header, l'm prototyping 1 right now. l'm also building a tuned length alluminum sheet metal intake manifold. For those interested, l'm building an over the top engine for myself afterwhich l will have a line of forged pistons, A beam & H beam crome molly rods, over sized valves, HP springs, titanium retainers, high capacity oil pan w/windage tray, 200 psi head studs, main studs w/optional main girdle & aluminum sheet metal valve cover.PROPOGATE! AND FACILITATE!
