I need help. I bought a Toyota idle up valve and solenoid off of the Bay.
On my custom throttle plate I have a vacuum diaphram. When vacuum is applied the throttle pulls down further.
I need the idle speed to increase when the air conditioner is on or the power steeing is cranked and the pressure is up.
Correct me if I am wrong. I believe the way it is supposed to be installed is the threaded portion to the intake manifold for full vacuum. And a hose between the the side barb and the throttle dashpot. I believe that as the electrical signal comes to the solenoid from the A/C, it causes a plunger to move and open up the valve so more vacuum can pull the throttle lower. I assume it does this proportionately.
Here are pictures I took of the assembly today from both sides.
