the rebuild for my engine is going slow... the head stuck on and can't get it off... might invest in a rubber mallet as i don't want to hit it to had with a metal hammer (even one wrapped in cloth)
So in the mean time I'm hoarding and modifying parts. ( which till now roughly translates fixing non-engine related things like a driver side mirror
Since both 121 and festiva's never came out in EFi (later model festiva's did aka Aspires to you) I'm looking at my options on carbi performance for my 'big block' build up.
The twin carb ford lasers and Mazda 323 all turn out to be E5 motors and the rumours that Australia produced a twin-carb B6T could prob be linked to the E5T motor.
So my options have to be a bit more err.. :idea: agricultural.
Idea's i have so far is:
-just using E5T twin carbs
- Twin or quad carbs from a large bike ( 900cc - 1500cc)
- Honda Twin Carbs
Looking closely at a carb intake manifold I'm thinking it should be to hard to modify into a twin Side draft manifold. Bike carbs would probably involve a scratch job.
I know nothing much about the Honda carbs (think they where in a prelude or accord circa 83) but what attracted to me to them was the fact the airbox sat vertical (parallel to engine) rather than on top of the engine like Mazda design. Also looked alot simpler to adapt providing there was enough clearance to the firewall.
So any knowledge about these options would be helpful, I'll have to research the carbs a bit more... be interesting to see what turns up cause a lot of japan only models had Twin Carbs in the early eighties before everyone virtually switched to EFi.
 )Since both 121 and festiva's never came out in EFi (later model festiva's did aka Aspires to you) I'm looking at my options on carbi performance for my 'big block' build up.
- Honda Twin Carbs
