I put off trying a B3 head on a B6 engine.... and found a deal on an entire B6 engine. OR SO IT SEEMS... read on:
Looking at the ID plate on the block it says "B3"! The top of the 3 looks like a "7" and the bottom looks like a "3". Does that sound familiar?
The guy said this came out of a 1990 Mazda 323. It has a 5-speed with hydrolic clutch. It might be a G series, I will have to find a mark.
So I am back to square one. Should I try to put this block/ head with my cable 4 speed? That is what I want to do. I prefer the smaller engine for economy. Should I?
How much cost/work to use hydrolic clutch, more than swapping transmissions?
There are some differences in harness connectors, and the intake is routed to the side - not across the valve cover.
Other differences that I will probably realize as I research some more here
Thanks, and remember the Kool-aid is for members...
1988 Mazda 323 hatch (festiva's ugly cousin)
Poverty produces creativity
