Can anyone tell me the size of the stock injectors on a 90-93 Festiva?
Stock injector size
Stock injector size
........... With a lever long enough and a place to stand, you could move the world..........
..................Build thread.................http://www.fordfestiva.com/forums/sh...ad.php?t=29547Tags: None
I found this.........
Ford Festiva......1.3L sohc 8v B3...195500-2110 ........120 cc/min.....13.9 ohms ....purple
Mazda 323.........1.6L sohc 8v B6...195500-1670 ........130 cc/min.....12.7 ohms ....green
Protege/Escort....1.8L dohc 16v BP..195500-2180 ........230 cc/min.....13.9 ohms ....beige
Mercury Capri XR2.1.6L dohc 16v B6T.195500-1300 ........300 cc/min.....13.9 ohms ....dark blue
And this...........
__________________
Note: To convert lbs. per hour fuel flow to cc per minute fuel flow, multiply the lbs. per hour number by 10.5092. For example, 42 lbs. per hour is equal to 441.3 cc per minute fuel flow.
Next question is....... If you change injector size,( to larger) do you have to re calibrate the VAF?
............ With a lever long enough and a place to stand, you could move the world..........
I may be wrong, but I don't think our VAF's are specific to the injector size, just the ECU. You just have to use the ECU that matches the injector size. You should be able to install 130cc injectors out of a B6 in a B3, as long as you install a B6 ECU.Brian
