I have an 89 escort 1.3 carb jobby. I saw some people had done the escort Weber conversion.While waiting for a stock replacement carb to show up, I thought, Hay, I have one of those Webers out back! So now I have built my adapter plate and I am getting ready to install the Weber. I am trying to see what you guys did as far as throttle linkage and ALL the vacuum lines from the manifold. I think all I need to keep is pcv, vacuum advance for distributor and brake booster. Is this correct? also, What wiring can I eliminate and what can I do with the egr stuff? Any help/pictures would be great.
Ps, I also just remembered that there are 2 vacuum lines currently going to the distributor, do I need both of these?
