Aspire coil in dist conversion to Festy dist with external
  • #46
    and it's magnetic pickup right?
    So where are the + and - for that?
    www.dantheoilman.com
    Go ahead and ask me why
    • #47
      coil
      the large plug on aspire is for ecu cam , ecu crank signal , power and grounds , the small plug is the power for coil and the negative trigger from the ignition module ( inside aspire distributor ) it also used for rpm in cluster.
      • #48
        hmmmm.
        Yeah, well here's the instructions:
        If anyone has a clue as to what wire I'm supposed to hook where.
        • #49
          wire
          white wire , in to the transistor in distributor, you need to remove the coil and it is the flat terminal under ignition plate.
          • #50
            Oh man, why does this sound like it just got complicated?
            thanks yvan.
            • #51
              Well theirs only 3 wires going to the coil. The , tach, a one used for testing. The to , the tach you'd probably have to wire up a adapter and the testing one dunno. You don't need to mess with the other connector.
              91 rusty Festiva 260k
              • #52
                ah ha!
                It finally sank in. I have to remove the coil from the dist to find both leads! Then hook up the white wire like yvan said. So I can't use the outside wires at all.
                God, I hope this is easier then I think.
                • #53
                  Alright, the next stupid question, how do I remove the coil from the disty?
                  I see a couple of screws on the outside that look like they hold the top half to the bottom half, but I don't have a 90 degree screwdriver short enough to get in there. Is that what I need?
                  • #54
                    ah ha!
                    There's a second in the middle of the post the rotor sticks onto, but I don't know if I should undo that.
