I've been looking at the MSD & Summit Racing sites to see about estimating a cost for a better ignition setup.
So far the "Sport/Compact Ignition" PN6300 should run around $200.
A universal fit Blaster coil PN8200 (couldn't find recommended PN8207) will be about $45.
The MSD igntion will have the added benefit of providing a convenient cutoff switch for theft deterrence and, I think, a rev limiter.
Is there any way to find out what this combo will do before I actually buy and install it, or is it simply "experimentation time?"
The coil alone may help, I suppose. It would be cheaper.
If I got the "whole thang" I'd expect a bit more than just "smoother running" and reduced emissions for my ~$250. I'd want some measurable hp and torque increases. Around 3-4 hp minimum, especially if it gave me more low end oomph. However, I think most benefits are in the higher rpm ranges.
If I want "more torque right now" I'll have to get that supercharger or at least some nitrous.
Would the MSD coil help a stock Festiva ignition with the B6 modded with improved breathing? In other words, is the stock Festiva coil "a bit weak?"
(A long time ago I read that the '81 Civics were definitely improved with an aftermarket coil because their stock one was weak.)
Karl
Karl
