Hello - A friend of mind recently purchased a festiva with a BP (BP09 ECU) swap and has the Exhintake mod. He was wondering on if he could get some driveability tuning done. I used the "search" function and it appears that it may not be worth it because the best option's are a piggy-back like Apexi S-AFC or a stand alone such as Megasquirt. Is this correct? I was hoping it was going to be easy and it was early Ford EEC... I know this is not the case, however.
He plans on forced induction in the future (hopefully near future) so it probably wouldn't be a waste of time to do a Megasquirt setup. Is there a better solution? I also read about a plug and play solution someone may be creating on the Protege' forum's using megasquirt? Is this true? How much does he/she charge for his/her setup?
Thanks ahead of time. If I missed a FAQ or thread please direct me elsewhere. I did read the all the FAQ's I felt applied and searched dozen's of threads.
Jake
Jake
good luck with your build
Poverty produces creativity
