Can u get different dif gears for a 92 5 speed? how low can u go? where to get them?
got gears?
got gears?
73 pinto sedan 2.0/auto stock
74 pinto h/b turbo 2.3/t5/8.8=4:10
79 pinto wagon 2.3/4speed light mods
96 f250 daily driver work/tow rig
93 festiva 1.3/5speed
1973 pinto custom teardrop trailer
http://www.youtube.com/watch?v=fzDxRzM4vMM
wanted cars
79 ford courier
60-70 datsun PU
LEE CAR
horizon 2.5 turbo swap
75 honda cvcc b18 or vteck swap
71 datsun 510 wagon (4th car ownd 1 i drove daily)
older vw rabbit & dasher
1936 ford truck
cobra kit turbo2.3 5speedTags: None
The festiva tranny has the longest final drive I believe VS the aspire tranny.
Festiva 5 speed= top end
Aspire 5 speed= acceleration
You can always go 4 speed if your looking for lower gearing. I have a 4 speed and its low enough to bark tires in 2nd gear if you pop the clutch while shifting from 1st. Im getting ready to do a B8 with a 4 speed. Its going to be a nasty combo if the tranny holds up.Last edited by 91_festy_Gl; 09-08-2010, 03:43 AM.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
wanted cars
79 ford courier
60-70 datsun PU
LEE CAR
1936 ford truck
all festiva and aspire trans have the same 1-5 gear ratios (even the 4 spds). but the aspire has a higher final drive (numericaly). swap in an aspire trans, OR swap in a G series and then you have more choices.Trees aren't kind to me...
i was referring ti dif gears,Originally posted by FestYboy View Postall festiva and aspire trans have the same 1-5 gear ratios (even the 4 spds). but the aspire has a higher final drive (numericaly). swap in an aspire trans, OR swap in a G series and then you have more choices.73 pinto sedan 2.0/auto stock
wanted cars
79 ford courier
60-70 datsun PU
LEE CAR
1936 ford truck
