Hello all
so for some of you that dont know what a catch can is, a vauge explination of one is: a metal cylinder/box with a breather that collects oil vapours/blow by from your engine
oil catch cans can be bought on ebay for 20 bucks plus shipping etc etc. this is the one i bulit for free with spare parts i had lying around... but one could make one for less then 4 bucks with some time and patients.
This also isnt a step by step DIY document, this is just to show that instead of buying one for 30 - 40 bucks, you can bulid one for 4 and put that extra money in your pocket.
Soooooo you need to start with some kind of metal container, and it just so happens my mom left her staples water bottle at home today!!!
Next you need a couple of these buggers..... you can find them at your local home depot but i had these laying around. Depending on your setup i only needed 2
Also you will need some hose clamps... i had these laying around too:
Next take the cylinderical object and drill 2 holes in it where you desire. the top one i used as a vent and i attached a APC breather thing which you can buy at any one of your local rice rocket stores, or at part source (but they are expensive there). You could also attatch an old PCV valve to it if you want to save some cash:
Use some teflon tape and start slowly screwing them into your catch can. This can be a pain but with patience it can be done, then mount it to your car:
Now this is how i routed my catch can, this is just the way i did it depending on your engine/application, you may want to do it differently but TADAAAAAA!!!!!!
this cost me 0 dollars, i will probably have to replace my moms water bottle..
**** disclaimer
DO NOT USE YOUR GF'S, WIFE'S, OR SISTERS LULU LEMON METAL WATER BOTTLE!!! THEY ARE 30 BUCKS CAD AND ARE EXPENSIVE TO REPLACE!!!!
**** disclaimer
i can put my finger over or near the vent that goes to the intake and i feel ZERO air... and even if i take my oil cap off there is still no air comming out.... i can slightly feel the pulses that the motor makes cause its running but other than that it has 0 blow by... im happy about that
