Ok sometime in the near future I am going to swap the B6 out of my 88 323 into my 91 Festiva GL my Festiva has power steering and the 323 doesn't. Can I use the power steering pump and brackets from the Festiva or do I need to find the power steering stuff from a 323 also both cars have a/c which a/c setup should I use I guess I should state that the Festiva has factory installed air I am trying to track down any random things I might need I also know that I have to use the Festiva crank pulley will the '91 pulley work or do I need one out of a '93
Power steering ?
The pump and bracket should bolt up to the B6 block, just might need to run down the bolt holes with a tap first to clean out the dirt/rust that might be lurking in there. As for the pulleys and such it all comes down to are the AC/PS pulleys ribbed or single groove?No festiva for me ATM...
I know but I would think that at least one person on here has a b6 festy with power steering I would think that since most other parts off of the b3 will bolt on to the b6 that the power steering would too but I am unsure and I just want to have all parts needed before I start the awapJustin Craig Paola Kansas my 4 passions, demolition derby,Ford 2.3s, my festiva and my kids
O.K> that helps so that I don't have to track down a 323 power steering setup( although more common on the 323 than the Festy)the a/c pulley on the 323 is a groove belt and the Festy is v belt so I need to swap the crank pulley? Also the 323 doesn't have an extra groove for the power steeringOriginally posted by htchbck View PostThe pump and bracket should bolt up to the B6 block, just might need to run down the bolt holes with a tap first to clean out the dirt/rust that might be lurking in there. As for the pulleys and such it all comes down to are the AC/PS pulleys ribbed or single groove?Justin Craig Paola Kansas my 4 passions, demolition derby,Ford 2.3s, my festiva and my kids
I had a festiva with power steering. It had a serpentine pulley for the a/c and p/s. It also had a b6 installed.
I'll be glad to answer any ?s I can-Greg
Redneck Engineer
FOTY - '09
Depends on the crank of the 323. If its the "small nose" as us Miata owners "loving" refer to the '90-'91 Miata cranks, then your '91 pulley should bolt right up to the 323 crank, then use your Festiva A/C and P/S and your good to go. If its a "big nose" crank on the 323 then I'm not too sure what pulley you would/could use to have a single v for the AC/PS since most big nose I've seen use the 4 rib belt for AC/PS.
Found this pic on ClubProtege.com, small nose is on the left, big nose is on the right:
As far as I know, Festiva's used the small nose up through '92, '93 and up were big nose. Miata's went to big nose after '91, and I believe the BPs in the Proteges/EGTs did the same. B6s though I'm not too clear on. If your 323 has the small nose crank and the ribbed belt for the AC then please PM me, I'd love to buy it from you!No festiva for me ATM...
I ran into a pulley issue when putting a '93 engine in a '91, had to ditch the A/C from the '91 (the '93 didn't have A/C) because I couldn't find a big nose crank pulley with a single v belt to fit the '93 engine. Hopefully yours will turn out better though
I went and looked at my Festiva and I was wrong it has a groove belt for the power steering and for the a/c so either pulley should work because the 323 is the same it just doesn't have power steering so I should be good and if the power steering and brackets will bolt right on then I'm good to go and bravekozak when I was at the j/y the other day I thought I saw a festy with a/c and power steering when I go back I will grab the hosesJustin Craig Paola Kansas my 4 passions, demolition derby,Ford 2.3s, my festiva and my kids
