are there 2 different types of g5mr cable trans?
  • are there 2 different types of g5mr cable trans?
    i replaced my trans with one out of 93 xr2. i noticed there is a large bump in the 5th gear cover. ive never seen one of therse
    As far as I know there's no difference between any of the cable tranny's
      but you see what im talking about right?
        Ya I see what your talking about.... From me taking apart a couple different probe tranny's, EGT tranny's etc, I have seen two different styles of 5th gears (located just under that cover) but I haven't noticed any differences in the covers themselves
          I think I'd rather have the flat cover for framerail clearance.
          91GL BP/F3A with boost
            me too... its hitting the frame rail... i didnt want to switch the cover without knowing if it would cause an internal clearance issue...
              ^^You can switch the covers without any internal worries
                i just might in a few days after my anger of 3 tranny swaps in 2 months wears off...
                  ^^Totally understandable :lol:
                    my friend told me it looks like the the same 5th gear cap on his klde...is it possible that some one swapped the bell housing side of the 4cyl and 6cyl g series transmissions?
                      ^^You can't swap the bell housings, but you can swap the end covers, so that would be possible
                        I have both cable trans and KLDE gtype end caps on hand here, I think I noticed the v6 cap stamping was just a smidge deeper
                        1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
                        Rocketchips!
                        Bolt-on Weber Carb Adapters!
                          I have a cable trans and a DE trans as well and I never noticed any difference, I'll have to look again :lol: I'll also check my Escort GT trans to see if there's a difference with that one as well
