Inject or harness
  • Inject or harness
    for all of you who remember i am doing a b6 swap, and i have a couple more inquiry's. first off i searched, and found nothing,
    I remember reading about how the only thing to do on the swap is change the injector harness over to the festiva harness, some people said it was plug and play others said they had to splice in to the festiva harness, now the real question at hand here is, what year did they come the same as the festiva wiring harness?/
    B6 with lightweight Flywheel, FMS street cam
    Holy heck gee willickers its fast!!drool
    Good question. I respliced everything but i imagine on some years you can take the rails off and just change to the b6 injectors and reuse the b3 rail/harness. i was one of the ones who left the whole b6 together on install and decided to play with wires instead of taking half the top apart because it was so close to running.
    1993 GL 5 speed
      im running a 90+ b6, i just used the festiva injector harness and spliced the new IAC connector into it (newer b6 uses different IAC motor). other than that one connector it fit on the b6 just fine.
      Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
      Dennis
      93 GL In progress BP/hydro G
      15 Mitsubishi Mirage daily
      88 Dakota tow pig
