this ebay item going for 200 dollars i might buy it to give a little more hp to my slightly modded b3. looks better than the other place ins, this one actually turns on not like the other cheap once
look at this looks very convincing
5 PSI? From that little thing? LOL!!
...and for $200.00?
Forget it.
It looks like the motor sits in the intake tract. It's probably more of an intake restriction than anything else.Last edited by JPT; 02-09-2011, 03:32 PM.Festiva: Because even my dog can build a Honda.
Someone should try it and post some results. When not on however it does seem like it would be in the way. Maybe a better idea would be a variable switch on the throttle body.
I say go for it....it's not my $200.
900W motor = 1.2hp and with that fan design, there ain't NO way it can generate 5 psi of sustainable boost. figure our 1.3 needs about 150 CFM at redline.
just found a calculator and it shows and ADDED 160 cfm to make 5 psi so that means the motor has to flow OVER 300 cfm under load.Last edited by FestYboy; 02-09-2011, 04:36 PM.Trees aren't kind to me...
HahaOriginally posted by perucho View PostFord Fester
Cucumbers work better. Higher electrical conductivity.Originally posted by Beans View PostLOL... You'd get more performance from substituting carrots in for your spark plugs.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
