wudddup 1.5L twin cam turbo frankenstien mazda motor!!
  • B6T TB is 52mm IIRC. I can measure tomorrow if you want.
    I do know BP/B6T TB's are not interchangeable
    1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
    Rocketchips!
    Bolt-on Weber Carb Adapters!
    • ^^ I measured one tonight
      But thank you for the offer :thumbright:
      WWZD
      Zulu Ministries
      • small update, just over 1500 kms on this setup, no issues whatsoever
        its time for more boost and a bigger intercooler, and maybe a better exhaust!
        • Is there an aftermarket exhaust manifold for that engine? I'd also consider water injection.
          1993 GL 5 speed
          • Maybe I missed it, but did you ever post pics of the motor mounts?
            • Originally posted by smokeshow View Post
              pg 11 meng.
              • Another month, how is she running?
                1993 GL 5 speed
                • Originally posted by getnpsi View Post
                  She is running good with 10 psi, my turbo is starting to let go the oil seals and my Valve cover gasket is leaking
                  there is a lean spot to where my afr's get to around 16 at 5" of vacum but immediatly go to around 12ish at 0"
                  I just bought a boost controler, and im on my way to get a supra intercooler and some other bits at the junkyard im going to feed 15psi through it and see how it likes it!
