I'm reading the ATX upgrade thread, but haven't seen anything about this. I considered keeping the ATX, but only if there's a lockup convertor that fits.
ATX upgrades - lockup converter available?
what's the difference between the Festiva ATX and the Aspire ATX, not to steal this thread or anything.... maybe it'll help with the topic being discussed...Andrew Walker
Current Daily Driver:
89 Nissan D21 SE V6 5 speed 4x4
Projects in the works:
84 Mercedes Benz 300D(T)(Baby) currently awaiting transmission transplant/ full on restoration
I think if I have to swap, it'll be to a manual. I just don't see me swapping an auto to an auto... But ya never know.
I'm guessing the Aspire ATX has the electronics and/or fluid passages for lockup, so simply putting the lockup converter in the Festiva trans would do nothing.Last edited by Christ; 05-17-2011, 05:41 PM.
Its hydraulically controlled I believe..swap the whole trans.
The downside is that the diff is shorter geared so you will pick up acceleration but probably run the same cruise rpm.91GL BP/F3A with boost
No transfer gears that I know of. If you know transaxles you could swap diffs with the festy trans. I dunno if f series auto and manual trannies can swap diffs but there's an f series 5 speed from the escort pony that has a really tall different gear...like 3.3x91GL BP/F3A with boost
Did some searching for ya. The ATX model for both the festiva and aspire 3 speed is F3A if I'm reading right, so I don't see why an aspire converter wouldn't work. It's not electronically controlled and everything for the TCC should be in the converter. http://en.wikipedia.org/wiki/Mazda_F3A_transmission
It looks like there was another auto used as well. Jatco 3N71 (nissan). I know my wife's aspire had the f3a.91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
92 L 5sp "Red" RIP
95 Grand Prix SE DD
Wife's Stuff:
89 L 5sp "Carby Car"
97 Aspire auto "Pink Panther" Build Thread
Spring 2013 IndyStiva:
http://www.fordfestiva.com/forums/sh...eet-April-20th
no differance in the ATX between the festy and aspire except the locking converter but it's not worth it really unless you swap in the 323 hydro ATX (currently searching for 2 or 3 to use myself).Trees aren't kind to me...
So, in theory, I should be able to just swap in the convertor and do some valve body mods to get it to lock up in all gears with a full manual shift.Originally posted by link5186 View PostDid some searching for ya. The ATX model for both the festiva and aspire 3 speed is F3A if I'm reading right, so I don't see why an aspire converter wouldn't work. It's not electronically controlled and everything for the TCC should be in the converter. http://en.wikipedia.org/wiki/Mazda_F3A_transmission
That would be the goal, anyway.
So, that's cool. Again, not sure if I'll actually keep the auto, or what insane purpose I had for buying the car.
I love micro cars.
Me too... but they are BIG... very big. and the festy auto is already pretty big. An Aspire might provide a enough room under the hood.Originally posted by FestYboy View Postno differance in the ATX between the festy and aspire except the locking converter but it's not worth it really unless you swap in the 323 hydro ATX (currently searching for 2 or 3 to use myself).No festiva for me ATM...
lock up is rpm related, you can't control it manualy (with the factory festy/aspire ATX) though technicaly you COULD do it with the second gen 323 trans that's also used in the MX3 and EGT.Originally posted by Christ View PostSo, in theory, I should be able to just swap in the convertor and do some valve body mods to get it to lock up in all gears with a full manual shift.
I love micro cars.Trees aren't kind to me...
It's controlled by a fluid passage, right?Originally posted by FestYboy View Postlock up is rpm related, you can't control it manualy (with the factory festy/aspire ATX) though technicaly you COULD do it with the second gen 323 trans that's also used in the MX3 and EGT.
There's a mod for a413 Chrysler trans (I know, these aren't Chrysler products) that allows full lockup on every gear, as well as full manual shifting.
The Festiva partially already has the capability to shift manually, because selecting "2" locks out 1st, although I'm not sure you can force 2nd great with the car already in motion, and I know you can't force 3rd.
If its anything like the a413, there is a fluid passage that is only open in high gear, which puts fluid pressure against the tc clutch forcing the tc into a 1:1 input/output relationship'
If that's the case, lockup in every gear should be possible by routing fluid to that passage in every gear. Likewise, the rpm at which the passage is opened is probably either controlled by a governor or differential pressure valve, which would make a pretty simple job of modifying the engagement rpm.
This is mostly conjecture, though, because I'm not likely to actually keep the auto.
However, since I'm not sure anyone I know would want the trans, I'll probably open it up and inspect, if only to try some stuff out.Last edited by Christ; 05-18-2011, 07:36 AM.
