Has anyone relocated the battery to another place up front? I'm going to use a pc-680 and put it somewhere but was wondering what others have done.
Non-OEM battery location, but not in trunk
I had mine on the pass side after a BP swap. Built a little tray for it where the airbox used to sit and used a ratchet strap for a hold down. It was a little tough getting it in and out, but not too bad and I only had to change it once I think.No festiva for me ATM...
What about using a small battery in the stock location, like a lawn tractor battery? Would that have enough juice, and would that then give you enough room, getnpsi?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
That's a Gel cell, you can mount it upside down.Originally posted by htchbck View PostBatteries usually shouldn't be vertical...
The Turbo Chrysler guys mount them under the fender in the wheel well behind the headlight.1963 Fairlane - future NSS drag car
Pm Motoxpress.....he has a small lawn/garden battery on the passenger side in a custom tray"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Sorry bout that, I spoke out of ignorance. Guess I shoulda looked up the pc-680 before I commented. Oops lolOriginally posted by Larry Hampton View PostThat's a Gel cell, you can mount it upside down.
The Turbo Chrysler guys mount them under the fender in the wheel well behind the headlight.No festiva for me ATM...
Sorry about that, the Odyssey pc-680 is a 1/2 size and weight gel battery that lacks in reserve capacity and CCA's but since i don't need amps and it's never cold they do last as long as they claim. That size battery is good to go on its side in stock locations, that's usually what i do. Mounting them post up is harder to do because they're so skinny. With a new bracket i can put it anywhere, in the past I've used really long worm clamp straps too. It seems that as i complete my swap no wiring is where the festiva wiring is, might as well move the battery too lol. I'm looking to make a marginally better weight distribution w/o having to go to the back.1993 GL 5 speed
