I am having problems understanding my car. The boost is not coming on normally. All of this is with a vj 11/14 with the wastegate ported and a 2.5" downpipe.
Stock intercooler, air box and ecu: Full boost (13 psi) at 3k. It held there all the way up to 7k.
Starion intercooler, rocketman ecu , open element air filter: Boost (10-11 psi) at 3k. Then boost comes up to (13-14 psi) at 6k.
I tried switching out the ecu's and it did nothing. Adding a 255 Walbro did nothing as well. I have boost leak tested it and there is only two tiny leaks at the throttle body gasket and idle screw. I have no boost controller and just have the boost cut unplugged.
