Does anyone know the difference between the B3('91 festiva)and B6 ('89 323) fuel injectors? I'm having a heck of a time figuring what to use on my swap! I figured I'd use the B6 intake, but the harness is different. So I removed the B3's, but the injector plugs are different. Without splicing the B6 plugs in (a tedious task!) I thought I'd use the B3 injectors, but will they flow enough fuel?
Injector flow rates?
Opps.. found this on a yahoo search. Hope this help other's as well!
" Next, unplug the fuel injector harness. It goes to 4 injectors, the blue plug (AIC) and green plug (coolant) then the BIG multiwire end attaches to the B6D harness. Remove it. Keep it though, you will need the injector 'plugs'. Next, cut off the Festiva injector 'plugs' from your B3 harness. Connect the B6D plugs to the harness. Green wires to Yellow wires, yellow wires to black. You'll see what I mean. (B6 uses Yel/Blk - B3 uses Yel/ Grn). Now, take the blue plug, and extend the wires about 6"-8" and the green plug about 6"-8".
here's the page:
