Ended up doing a complete rebuild on the '89 B6 SOHC for my swap. The B6 appears to have been neglected and was full of carbon and cooked oil. I stripped the block down and am having it machined.
There are (2) bronze plugs that are in the end of the main oil galley that runs along the filter side of the block. The one at the back is obviously behind the bell housing, and the one in front is behind the oil pump assembly. I assumed they were similar to a brass freeze plug, so I drilled a hole in the front plug in order to remove it (to clean out the oil passages). Ends up, it's a piece of solid bronze that's about 1/4" thick.:banghead:
Are these plugs available new, or am I going to have to have some made out of bronze bar stock? Has anyone else gone through this before, and if so, what did you do?
