I'm trying to get my E85 setup working right on my 92 b6 sohc. With 336cc injectors from a Scion TC, they are the skinny type so you can ramp up the duty cycle up just a bit more, an adjustable fuel pressure regulator set to 60psi, a wolbro 255lph pump in the tank, and an Apexi safc, I still get fuel cut after 10psi and i keep thinking my injectors are not getting enough fuel. Anyone know if any bigger fuel rails could be modified to fit?
b6 fuel rail question
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig -
What injectors were you using before e85? Are you talking about a fuel cut after 10psi at the fuel rail? I probably won't be able to help you, I just want to understand the question :p2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
I was running stock BP 254cc. By fuel cut I mean there is a heavy misfire from leaning out. This a newer setup, a couple thousand miles, and still dialing it in.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
are you sure it's not spark blowout? 10psi is something a stock fuel pump and 323gt injectors can handle easily. i would suspect a non fuel issue given what you have on the engine.
BTW, how's the oil consumption?Trees aren't kind to me...
I do also have an Accel 42,000kv coil with 8mm solid core wires. I'll try lessening the gap a little. The oil issue was the same as always. I finally got around to harvesting and ultrasonicly cleaning some used HLAs and installing them on Thursday. The slight amount of HLA tick I had is completely gone so ill check the catch can on Monday after work.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
you can use an aspire rail with the plenum and you gain a schrader valve you can use for a screw on FPR install or a higher diameter feed and return line., just throwing that out if you can score those parts free or near to free.
cough i do have an aspire rail and its stock injectors lying around1993 GL 5 speed
LOL, so the aspire rail is bigger than the mk2 b6 rail? Keep in mind I'm running E85, a lot more fuel is needed.Last edited by gauge_half_inch; 12-24-2011, 11:41 PM.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
ok so your saying it went back to the way it was before madness or since the trip home? i'd hate to think that the baffle stopped working after only a few days.Trees aren't kind to me...
Yep. The valve tic got a lot worse also.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
336cc's is WAY too small for e85... youll wanna get at least 700cc's if you wanna make any sort of power out of it
i was maxing out 370's on 14psi of boost on 91 octane in my B6T on 50psi of fuel pressure
im gettin 1200cc's for my e85 BP buildLast edited by fastivaB6TG25MR; 12-25-2011, 09:57 PM.I know its a piece of crap but im still faster...and its 100% legal!!!!!
crap, i thought i was on to something there... it didn't come loose did it?Originally posted by gauge_half_inch View PostYep. The valve tic got a lot worse also.Trees aren't kind to me...
Will the sohc b6 fuel rail flow 700cc? The baffle is still were you installed itLast edited by gauge_half_inch; 12-25-2011, 10:12 PM.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
my buddy was running 900cc's and making over 500whp on the stock square egt style fuel rail... the rail is a hollow tube and is not a restriction... its bigger around than your fuel lines so it only makes sense that they will become a problem before your rail willI know its a piece of crap but im still faster...and its 100% legal!!!!!
Would a B6T fuel rail fit? They're freakin massive.
I agree, 330cc is about optimal size for a B6 turbo on straight gas, but way undersized for e85
What's the percentage, like 65% larger for equivalent e85 setups?1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Idk is the b6t rail will fit, that's the reason for this thread...Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
