Look at these:
From the page:
They got 'em for the standard B6 at $154.00.
Worth it for that last little bit of performance on a nicely built engine, or just a gimmick?
Karl
From the page:
HotWires create a tremendously powerful plasma discharge that ignites every fuel mixture, rich or lean, much better than a conventional spark. Combustion is more complete, resulting in increased horsepower and lower exhaust emissions. HotWires are engineered with a special built-in capacitor, exclusive only to HotWires. This revolutionary design allows spark energy to accumulate in the capacitor until the voltage reaches the ionization point. At that split second, the entire power of the stored spark is discharged at once. The resulting spark is up to 300 times more powerful. Combustion is faster and more complete, resulting in increased horsepower and a cleaner burn. Replacing conventional ignition wires with HotWires is the easiest way to increase the performance of any engine. HotWires can be custom-made to fit nearly any application.
Easier Starting Engine
Improved Acceleration
No More Spark Plug Fouling
Cleaner Combustion Equals Less Pollution
Higher Efficiency
Higher RPM Limits
Lower Cycle to Cycle Variation
HP & Torque: Average 2-5% Increase HP and Torque
Installation: This custom wire set will fit exactly like a stock set of wires. No assembly required.
Tech Notes: When spark plugs with a resistance of less than 0.5 Ohm are used, Hotwires will give the biggest performance increase. When using Hotwires on highly modified engines (turbos, supercharger, NOS, high compression), spark plug gap should not exceed 0.9mm (0.035inch). 50 State Smog Legal
Higher Efficiency
Higher RPM Limits
Karl
