Does anybody have a wiring diagram for installing an msd 6al box to a b6t? Im confused about what color of wire the White wire coming from the msd box connects to? It says it goes to points on distributor
MSD 6al install?
use the green and purple wires to hook up to your distributor. you cannot wire it straight to the factory wires. you must take the Ignition Controle Module out of the distributor and wire it straight to the pickups. if need be i can take a couple pictures.
-W.F.Automotive Misfit
I removed the ICM and these are the wires that were connecting.
i see the green/yellow-stripe wire on the left.. is the wire on the right the purple one that i use? it appears red/brown on my car but either way i need to get this wired up.
i was also wondering if i could just use a male ended electrical connector to wire my msd to those wires if they are the ones im supposed to use.-93' Festiva L (B6T swap in progress)
-92' XR2 Capri (Parts car)
okay i found the green and purple violet on the msd 6al.. so does the green on the msd go to the green wire in the distributor and the purple from the msd to the red/brown in the distributor?
(edit: i just saw that it says green is negative and purple is positive.. so the green in the distributor must be the negative and the other wire must be a red positive right?)
back of the msd 6al
Last edited by festivBS; 06-13-2012, 04:14 PM.-93' Festiva L (B6T swap in progress)
since when??? the modual MUST be used to send signal to the 6AL. i've installed 2 systems (both the same way) and used all the factory pieces (excepted upgraded coils). i wired it in such a way that if the 6AL were to fail for any reason (and they DO), you could easily go back to stock and get home.Originally posted by wflaw45 View Postuse the green and purple wires to hook up to your distributor. you cannot wire it straight to the factory wires. you must take the Ignition Controle Module out of the distributor and wire it straight to the pickups.
-W.F.Trees aren't kind to me...
i used the white wire tapped into the ICM output IIRCTrees aren't kind to me...
