FMS B3 cam in B6 SOHC?
  • FMS B3 cam in B6 SOHC?
    wondering if this will work for my build? using an early B6 SOHC with carb intake and weber carb. The sale has tempted me to jump at it and try just wondering if anyone has done it themselves.
    Thanks
    -W.F.
    Automotive Misfit
    I did it. The FMS cam does make the car peppier but fuel economy dropped about 3 MPG. I eventually put the original cam back in. Runs smoother with the original. Depends on what you want. It definitely will work though. You are building my exact setup. Makes a pretty fun little car.
      Awesome thanks! not too worried about fuel economy with this one. time to break the head open for porting
      Automotive Misfit
        ^ focus on the intake bowl and exhaust runner shelf. then deck the CRAP out of it (0.020" is the "safe" limit to give you some starting point)
          The exhaust bowl (on the first gen at least) is worse than the intake bowl. It is terrible. The short turn radius on the exhaust is bad, but the port floor and one wall is flat, and the port is skewed to direct flow toward the opposite corner. There's not a lot of meat there to really get a good radius. About all you can do is get rid of the sharp edge and hopefully reduce turbulance. I wish I had a flow bench and 2 old heads to really experiment with!
