^^^AGREED!!! I have 2 carb cars that will get the switch over to efi.. Carbs are ok if you are just getting a local grocery getter, but if you plan on any swap for performance then efi is the cheapest (and IMHO the best) way to go, you'll be changing out the harness and computer as well as the fuel lines, tank, fuel pump.. etc.. etc..
4 Speed vs 5 Speed?
The carbed Festys are fine if you're gonna keep it a stocker. It's also fun to play with upgraded carbs, etc. Been there, done that. Don't do it if you like your fuel mileage
If you're buying for a gas miser driver, the carbed Festies are just fine. If it runs well now, it will run well for years.
jeff
